how to trim the staircase lower part that connect with the slab ?
SPIROS VOUTSELAS
Hi all.
how can I  trim the staircase lower part that connect with the slab ? I tried solid elements operation ( even with "downword extrusion ", I chabged also priority of building materials ( different concrete for slab and staircase body ) but had no luck. ANy suggestions ? Thank you in advance
Rajesh Patil
ā€ƒIs this not working for you?
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
Rajesh Patil
Rajesh Patil
SPIROS VOUTSELAS
Rajesh thank you very much !!!!!!
Rajesh Patil
you welcome šŸ˜Š
Rajesh Patil
