i have a inviisble wall
the wall is visible in plan but not in section, elevation, or 3d
the windows in the wall are visible in these views but the wall itself is not showing up. I can select the wall in 3d and elevation but you cant see it, just the selection nodes. I restarted Archicad but that did nothing.
Thanks for the help
There are a couple of things to check...
Make sure there is not a second wall in the same location.
Also, check your renovation status of the wall and the filter for each view (Section, 3D window etc) as the Reno Filter stays with the view, not the current Plan view.
