ā2011-01-28 01:03 AM
ā2011-01-28 01:45 AM
ā2011-01-28 01:55 AM
ā2011-01-28 03:05 PM
wildernessbob wrote:If you are referring to the Project Map, the Details (and other folders) cannot be deleted, so I am guessing that you are referring to the View Map. You can create a new folder, but you will need (usually using the Organizer) to pull Views from the Project Map to this folder in the View Map. If you set up a template with this already done, then you will not need to do it again for each project.
i've somehow deleted my detail view folder, i've tried to replace it by creating a new folder, but new views are not placed i it. they end up at the bottom of the view list. can i get it back?
