‎2004-04-29 08:43 PM
‎2004-04-29 09:08 PM
‎2004-04-30 03:30 AM
‎2004-04-30 05:35 AM
‎2004-04-30 09:43 AM
‎2004-04-30 02:30 PM
Michele wrote:Interestingly, you can Add two Walls with Solid Element Operations (SEO), but I don't know if this is of any use to you. You will then have to put the operator element on a hidden layer to see the result correctly.
Can Archicad join 2 walls so that they act as one? I have 2 walls that clean up to look like 1 but I want to "merge them into each other. Is it possible?
Thanks,
Michele
