library parts- move from one comp to another
I have just moved one AC 10 file from one computer to another. The windows do not show up. It says that it is not available in the loaded libraries. How do i transfer library from computer where file was originally created?
-thanks
1 REPLY 1
Aussie John
Locate the windows manually in windows (or finder on Mac) and copy them to the folder you wish to load as the library. If you are moving computers often it may be best to have one library on a server (or dedicated computer) else use syncing software to make sure all your libraries are identical.
Cheers John
[/size]
