lineweights in section
Although I have chosen a particuar pen for the walls, say #17, it only appears at this thickness/ color in plan...in the section the lines appear to be fat and black, no matter what I change the pen type to. How can I get my section lines to appear as I want them to? Am I missing a toggle? Am I one toggle shy of a full array? As they say.
TomWaltz
Check your Section Marker. Under "Cut Element" It may not be set to "Use Elements Own Pens"
Tom Waltz
yes precisely exactly.
thank you.
