Have a module of a typ. apt. unit. Changed windows in the module, then saved and updated module on original. Windows look like "simple"; do not update to the detailed version on the module. Seems like a model view setting....but can't find one.
Changes to the window parameters should update to the apartment modules in the building file. I have never had a problem with updating modules. Are you publishing them or linking direct to the PLN?
silly response I know but you are looking at the module and the plan at the same scale?
Cheers John
OSX 10.15.6 [Catalina] : Archicad 22 : 15" MacBook Pro 2019 [/size]
