Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
macOS 10.12 Sierra compatibility updates
Csaba Kezer
Dear All,
In order to reach compatibility with the upcoming release of macOS 10.12 Sierra (planned to be launched on the 20th of September) GRAPHISOFT re-creates some of it’s version 20 Release Packages and releases it’s next Updates for ARCHICAD 19 and 20. These updates fix already discovered macOS 10.12 Sierra specific issues. If you would like to upgrade to macOS 10.12 Sierra, please make sure to install these Updates beforehand. GRAPHISOFT addresses already detected Sierra compatibility issues with the below packages, but cannot guarantee that further issues will not arise at a later point. Visit our always up-to-date Help Center article on Sierra compatibility to learn more about the known issues.
Version 20 Release Packages re-created
We have re-created some of our ARCHICAD 20, BIM Server 20 and BIMcloud 20 Release Packages to fix incompatibility and start-up crashes with macOS 10.12 Sierra. Only those language versions are affected with these issues which were initially released with Build 3012 (INT, USA, UKI, AUS, NZE, GER, AUT, FRA). GRAPHISOFT replaced all Build 3012 packages with Build 3016 on the Download sites (Electronic Delivery, https://graphisoft.com/downloadshttps://myarchicad.com)
The rest of the v20 language versions were released with Build 3016 or higher, therefore those versions reach basic compatibility with Apple’s newest operating system out of the box. Version 19 and earlier packages are also unaffected by the Sierra specific issues.
ARCHICAD 19 & 20 Updates
We released our newest Updates for ARCHICAD 19 and 20. Besides all corrections since the last Update, these packages contain additional fixes to address macOS 10.12 Sierra specific issues as well. The Updates passed our Quality Control for the INT, USA and GER language versions so far.
You can read the Release Notes and download the Preview installers from here:
ARCHICAD & BIM Server 19 Update 7006
BIMcloud 19 Update 7006
ARCHICAD & BIM Server 20 Update 4012
BIMcloud 20 Update 4011
We plan to publicly release the update for the rest of the language versions as soon as they pass our Quality Control.
Best regards,
Csaba
Csaba Kézér
Director, Global Customer Support
0 REPLIES 0
