mesh bug
160814 EDIT: When heights of hotspots of mesh were edited one after the other the last used command were not retained by Pet Palette
this bug is not solved with last hotfix!!!!!!!
7 REPLIES 7
Eduardo Rolon
In US 5014 version it is fixed.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
I use international version and it is not working.
I also use the INT version build 5014 and it works for me both in 2D and 3D.
it is working if you try to modify nodes on the mesh edges, but it is not working with nodes in the middle of the mesh.
Eduardo Rolon
Just tried it again and it is behaving correctly on both the perimeter and inside nodes.
The bug I just found out is that if you select "Elevate Node" from the palette when yo click the next node and select cancel the pet pallet disappears and you cannot switch to another option. This is for interior nodes, the cancel works for the nodes at the perimeter.
AC27 US/INT -> AC08
another Moderator
well that is the bug I am referring to.
probably I haven't explained correctly.
David Maudlin
Discussed and acknowledged here:
Bug with pet palette when editing mesh
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
