Llian
mesh gravity tool
i don't have the manual and surprisingly the help doesn't quite provide help other than pointing to where the tools really are. anyways, attached is mesh tool where is the gravity tool so the spot elevations are showing the grade elevations?
my other problem is i can't delete the spot elevations which i have placed on the bottom left corner which are all showing as +0.00. When i clicked on the symbol and hit delete, the whole mesh got deleted as well.
patiently learning!
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
13 Replies 13
patiently learning!
The Gravity option is on the top tool bar next to "Virtual trace" it looks like a small weight ( giving options of gravitate to mesh , slab or roof) .
the level dimensions are not linked to the mesh so when you are deleting and the mesh is deleted ..then for sure the mesh is selected ... maybe its hard to select it because its at the corner ..many ways to do that .. one is to draw a marquee around it .. select the level dimension tool from the tool box and then ctrl+A ( apple+a for mac) . and delete.
or usually when you have overlapping elements before selecting it just put the mouse over it and click tab it will switch between the elements ..select what you want .
Erich
Llian wrote:
i don't have the manual...
Look in your Help menu for the AC 13 Reference Guide. All legal installations of Archicad include the pdf manual. Generally this is much better than the Archicad Help option in the same Help menu.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Llian
Erich,
So you know it's the Archicad 13 Education version downloaded from graphisoft site ..is this legal ??
Llian
Can someone be so kind to highlight in the archicad 13 work environment where is the gravity tool on the top bar as someone suggested here????
picture says alot doesn't it??
Rod Jurich
Llian wrote:
/.....picture says alot doesn't it??
Unfortunately GS deem it appropriate to NOT SHOW the Coordinate or Control palettes
Set up your WE to have these 2 palettes to show. See attached.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Llian
Thanks Rob! i did it. i notice the gravity icons appear only when the wall tool is selected and not the mesh tool. any rational to that ?
Erich
Llian wrote:
Erich,
Yup, all on the up and up. Did you find the pdf manual?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Llian
do you mean the Interactive Training Guide 1 and 2 ..yes i have but the arhicad movie player is not working from chapter 06 on....
Reread Erich's 1st post.
"Look in your Help menu for the AC 13 Reference Guide."
lec
