2004-05-19
09:32 PM
2023-05-25
05:17 PM
Rubia Torres
2004-05-19 09:36 PM
Jens wrote:Something is wrong with your mesh. Can you post the screenshot of the plan? Some outlines are probably overlapping.
I created a mesh with the Magic Wand and Polylines. It is visible in the 2D but not in the 3D.There is always the warning" Invaild Polygon, self intersection or hole intersects boundary" hm ?Thanks
Jens
2004-05-19 10:12 PM
2004-05-19 10:20 PM
Jens wrote:Hmmm ... did you do it with the Mesh or with ArchiTerra? Looks OK to me, but Fabrizio of Cigraph fame will know if something else is wrong.
Here is the screenshot of the plan.
2004-05-19 10:45 PM
2004-05-19 11:07 PM
2004-05-20 12:33 AM
Jens wrote:When I see this happen, it usually means there is a problem with an arc used to generate the mesh perimeter, usually that the arc crosses the rest of the path. This can happen at such a small scale that you can barely see it even when zoomed in. I've attached an exaggerated example of the problem.
I created a mesh with the Magic Wand and Polylines. There is always the warning" Invaild Polygon, self intersection or hole intersects boundary"
2004-05-20 07:54 AM
ashley wrote:Use the Vaulted roof. Draw the profile of the wave, magic wans into the roof.
I have problem with mesh tool, too. I want to build it like ocean wave. BUT somehow it alwas show up as a flat plan.
