roof surfacer upside down
I had this same problem in 7.* but no solution, but I never asked the question either THe procedure I use is to select the roof go to extras and select roof accessories and then roof surfacer apply settings, in this case none, and BAM there we go. I look in the 3d window to check how it looks and the tiles are going up hill. What am I doing wrong?
7 Replies 7
Shae,
I managed to reproduce the roof surface being upside down.
I made a roof with a negative roof pitch and then used
the roof surfacer and the Italian Tiles were upside down.
Maybe that is what is causing the problem.
Peter Devlin
vfrontiers
Peter wrote:
Shae,
Peter Devlin
You are close [to the reason and the solution]....
My best guess [unconfirmed] is that the direction is determined by the drawing of the roof slab [clockwise or ccw] or the spring line... I cannot determine how it calcs this... BUT...
to resolve it, simply grab one end of the spring line and drag it to the other side of the other end of the spring line [your roof will be pitching the wrong way now]... THEN stick a MINUS sign in front of the PITCH in the INFO BOX.... and the tiles will invert for you... If they are still LINKED, you will not need to create a new set of tiles....
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
vfrontiers
While we're talking about ROOF SURFACER... DYK...
If you modify a roof with the surfacer layer turned off, the surfacer will be incorrect when you turn them back on... To correct this... simply select the ROOF SURFACER, cmd-t [open settings] and say OK... it will heal itself to the roof modifications.
Duane
Visual Frontiers
AC3.14 - AC29
Duane,
You say in your post "If they are still LINKED".
How do you unlink them?
Peter Devlin
Djordje
A screen shot would help your problem explanation?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
__archiben
and whilst we're on the topic of the roof surfacer:
(i'm using the 'standing seam' type)
  • switching from simple 3D to detailed 3D generates a GDL error every time no matter how i fiddle with the parameters.
  • 2D detailed view, always stays at 400mm centred sheets no matter what i set it to.
. . . or is it just me?
~/archiben
b e n _ f r o s t
vfrontiers
Peter wrote:
Duane,
Peter Devlin
If, for some reason, you cut and paste the SURFACE, it is no longer linked....
Duane
Visual Frontiers
AC3.14 - AC29
