mesh
oh why oh why is the mesh tool such a night mare to use !!!???
why oh why when so much else is such joy the mesh tool is such a complete mind messer ?????? please do explain ????? how can solid elementing a road be such a complete and utter time stealer any helper out there with nothing better to do than explain the how the the hell this works ?? - thanks all
1 REPLY 1
Eduardo Rolon
Doing too much right now but know that using the mesh is not that much of a pain. Once you have the procedure down it is easy to maintain and use.
Concept/Ingredients
• 1 Main Mesh
• 2 Meshes per item, one for Streets and one for Sidewalks. If site is bigger than 2 -3 acres then you should break it down.
• One layer for the Mesh and one layer for the Mesh SEOs with a different intersection number. Do not use slabs or any other items for the SEO, only meshes. If you do then it will slow your file down.
• For editing you could/should do it in 3D since then you can edit multiple meshes at the same time if the nodes align.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
