Learn more
RandyC
missing menu
does anyone know where I can find this menu ? it is not showing under "file"
nor does it show in Work Environment - is it only available on Mac ?
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
18 Replies 18
Dontknow
When you've got no library loaded this section of the menu doesn't show.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
RandyC
library is loaded --- the menu does not show
Dontknow
The last image is another menu-item than in your first message.
Which one are you missing?
ArchiCAD 25.
RandyC
The trouble is with my scheme in work environment
if I load the standard scheme the (save selection as ) is available
If I load my scheme or the command layout scheme the
(save selection as) is not available.
RandyC
the other screen capture showing my scheme - note the command layout
scheme also does not have this file menu
Dontknow
Ah, I see what you mean.
Hmm, good question.
Under 'Application commands and menus' they should all be there.
'Save Selection as...' is not the only thing which is missing.
At this point I've have no idea why it's missing.
Maybe you should make a new scheme.
ArchiCAD 25.
Erich
What you are looking for in a predefined menu. If you are lacking the menu, for whatever reason, just recreate it by defining a new menu and adding the appropriate commands.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Dontknow
The point is that he doesn't have the menu item 'Save Selection as...' on the left. It's missing so he can't ad it.
ArchiCAD 25.
RandyC
that is correct DontKnow
-- making a new environment can be time consuming ---
--- seems like a bug to me --- maybe someone knows a simple way to get it back ?
