missing menu
RandyC
does anyone know where I can find this menu ? it is not showing under "file"
nor does it show in Work Environment - is it only available on Mac ?
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
18 REPLIES 18
Erich
The "Save Selection As" menu is only four commands long. Do you have the commands themselves? (Look in the All Commands in Alphabetical Order" from the List toggle. If so, building a four command menu and adding it to your WE is a matter or a minute or two at most.
If you are missing both the menu as well as the commands that is something different.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
RandyC
i was missing all of the commands - none were available --
I am in the process of rebuilding my work environment
one thing I notice is that Archicad 18 does not allow individual commands in the menu bar ( I have been importing my environment with each upgrade and adding any new commands ) and my old menu had several individual commands(not menu's).
Erich
By not having the commands do you mean "Cabinet Door", "Curtain Wall Cap"....
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Erich
If so, you want this command shown in the attached image.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
RandyC
I had none of the commands ---
I also did not have the "save selection as " menu
I am now rebuilding my environment so I do not want to go back.
however I can send you a link (or graphisoft) that contains my old
work environment - then you can see that these commands, menus do
not exist.
I believe it happened from moving my environment from version to version without doing a complete rebuild.
Erich
In the last image notice that the "No CC Subtypes" is the command that adds all the others ("Cabinet Door", "Curtain Wall Cap".... etc.) that appear in the "Save Selection As" Menu. They do not appear separately in the command list.
Transferring your old WE may mean that the menu is not visible or just does not exist, but the command "No CC Subtypes" should still appear under the "All Commands in Alphabetical Order" list. That list is independent of the WE applied. You can see it in both columns in the previous image.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
RandyC
Thank you Erich ! I was able to find the commands by following your instructions
I had to create a new "save selection as" and "library" menu then add the command "no CC subtypes " (not sure what this command means)
success !!
Erich
Glad I eventually helped!
Yeah, "No CC Subtypes" is not especially descriptive is it.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
This topic shows that when editing Menus we could use a Copy Menu/Paste Menu functionality. In that case you could have just copied the "Save Selection As" menu from the Standard Profile and pasted it into your other profile.
