2012-05-08
01:16 AM
2023-05-23
02:42 PM
Rubia Torres
2012-05-08 02:04 AM
2012-05-08 03:28 PM
2012-05-08 11:42 PM
knosaj wrote:If you place the roof pivot line (setout) on the INSIDE face of the wall (as Matthew suggested) you have a birdsmouth the width of your wall. This is how I always set my roof out.
So, for example, if my top story is a 9'-0" plate, and if i specify the roof to be at a 9' plate as well, ArchiCad will place the underside of the roof plate exactly on the outside of the wall at 9'0" which means there is no setting that takes into consideration a notched birds mouth?
knosaj wrote:I have used several different methods for this depending on the flexibility you need for end cuts etc. If not the rafter object (easy to edit them all at once parametrically) I have used a small section of roof and the Multiply command to distribute around the building.
----how about the exposed rafter tails?
would these be modeled as separate elements?
-is it best to do this with the rafter tool, or as a beam?
thanks again everyone
2012-05-09 02:57 PM
2012-05-11 02:36 AM
2012-05-11 06:15 AM
knosaj wrote:Complex profiles can make this very easy - see an illustrated example here:
