modelling a r.c.c framed structure
hi all
we mostly deal with r.c.c framed structure here in india my question is for wall height how to manage different wall height according to beam depth that will be different for all wall . in r..c.c structure wall sits below a particular beam and beam supports the slab / wall acts as partition only and are not load bearing
4 Replies 4
Srinivas
By Setting the beam Priority higher than wall priority, beam will automatically cut through the walls.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
vistasp
Mentor
AFAIK beams automatically have higher priority than walls.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Srinivas
Beam Priority is set to 7 and wall priority is set to 8 by default, which I think should be the other way around, not sure why they kept it like that in the default template.
ArchiCAD Service
Mac, Windows 11
vistasp
Mentor
You're right Srinivas, it is the other way around. I guess I've been using favourites for so long that I forgot what the default was.
= v i s t a s p =
bT Square Peg
