‎2019-05-15
06:47 PM
‎2023-05-24
07:22 PM
Rubia Torres
Solved! Go to Solution.
‎2019-05-16 08:09 PM
‎2019-05-15 08:15 PM
‎2019-05-15 08:25 PM
‎2019-05-16 01:35 AM
tenak333 wrote:By cover, do you mean roof? it is no problem to make two arches, offset them, and make use a morph to cover them if that what you mean. https://www.screencast.com/t/PcMe3UhMm
Does anyone know why can't I get a good cover for the morph?
I get either some weird surface or completely flat one.
Thank you!
‎2019-05-16 11:13 AM
‎2019-05-18 01:11 PM
‎2019-05-18 08:12 PM
‎2019-05-18 10:29 PM
‎2019-05-19 02:58 AM
LaszloNagy wrote:I assume that it doesn't matter too much because there is going to be a limit. Use all 1's if you like. Typing in a bunch of 9's is just a way to make sure you have reached it. For all I know 99 is enough I don't care, as long as I know I have made it as smooth as it cab be. And like I said, I never have any problems with making everything as smooth as I can. The idea is to just click one digit any digit not 0 a few times because we don't know what the limit is and 7777777777 or what ever will do the job.
That 9999 resolution sound way too much to me. That means that a full circle is approximated using cca. 10000 lines, a half-cylinder is approximated using 5000 polygons, a half-dome is approximated using 5000x5000 polygons, just for a single object.
The default resolution in GDL is 36, so a resolution of 72 or 108 or 180 could be more than enough for display purposes.
Of course it also depends on the absolute size of the element. A 100 m element will need a higher resolution than a 10 m element.
