‎2005-11-16 01:19 AM
‎2005-11-16 01:50 AM
‎2005-11-16 02:07 AM
‎2005-11-16 02:38 AM
Zobi wrote:Select your items in plan and then FILE menu > MODULES & XREF-S > SAVE SELECTION AS MODULE...
that sounds like the right idea...how do I save it out as a module? do you mean, build it in its own, external model, save in as its own /pln, and then import it as needed?
or is there a more refined function?
‎2005-11-16 02:41 AM
‎2005-11-16 02:54 AM
Zobi wrote:You can only have one file open in Archicad at any one time (and as you discovered you can copy, close the file, open a new one and paste).
why, so you can! how delightfully simple. I thought that since you could only have one AC model open at a time, you couldn't copy and paste...a little more laborious, but not too shab, overall. I'll try the other trick, making a module, as well.
Many thanks!
‎2005-11-16 03:35 PM
Barry wrote:
But there is nothing stopping you having 2, 3 or 4 Archicads running at the same time (except you machine specs), all with different plans open.
‎2005-11-16 04:24 PM
Stress wrote:Be careful with multiple Plotmakers. I once tried to plot from two different sessions to two different plotters, and found out that both sessions read the same settings. When I changed the plotter in the second session, all my plots went to the same plotter!Barry wrote:
Just make a copy (or copies) of the ArchiCAD application file. Works for multiple Plotmaker app.s too.
‎2005-11-16 07:12 PM
Stress wrote:This action must be for the Apple users.
‎2005-11-16 07:16 PM
