moving chunks of a model from one file to another
Does anyone know how to move a chunk of a model to a file with another? Must I make a GDL of it? Current example: a porch railing that we will use in lots of different models. How best to transfer it from one model to another?
many thanks..!
15 Replies 15
You could make a library part out of it, but a better solution would be to save the rail out as a module file and then it can be merged into a new file.
that sounds like the right idea...how do I save it out as a module? do you mean, build it in its own, external model, save in as its own /pln, and then import it as needed?
or is there a more refined function?
Select your items in plan and then FILE menu > MODULES & XREF-S > SAVE SELECTION AS MODULE...
You can also simply copy and paste from one PLN to another.
why, so you can! how delightfully simple. I thought that since you could only have one AC model open at a time, you couldn't copy and paste...a little more laborious, but not too shab, overall. I'll try the other trick, making a module, as well.
Many thanks!
Many thanks!
You can only have one file open in Archicad at any one time (and as you discovered you can copy, close the file, open a new one and paste).
But there is nothing stopping you having 2, 3 or 4 Archicads running at the same time (except you machine specs), all with different plans open.
Stress Co_
Just make a copy (or copies) of the ArchiCAD application file. Works for multiple Plotmaker app.s too.
Marc Corney, Architect
Red Canoe Architecture, P. A.
TomWaltz
Be careful with multiple Plotmakers. I once tried to plot from two different sessions to two different plotters, and found out that both sessions read the same settings. When I changed the plotter in the second session, all my plots went to the same plotter!
Tom Waltz
This action must be for the Apple users.
Stress Co_
Yep, how do you do it on a PC?
