need help with columns
Hi. I use ArchiCAD 10, and i don't know how to create horizontal columns. Help me plz,
10 Replies 10
horizontal columns? i prefer calling it beams?
beams are only rectengular or profile, how to make a circle in its cut?
profile
Stephen Dolbee
There is also a cylinder library part that might work for you.
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
thnx, but: about cylinder library part - where can i find it? And about profile: i tried to make a circle in profile with profile manager tool. Yes it works, but i cant change it radius, it's constant value 😕
You can find library objects using the "find library parts" option in the object settings pulldown.... then enter a keyword
Dwight
Yikes!
If you are making round columns, they are right there in the column tool.
Once you make ANY custom profile, that profile CAN be edited - ie: radius change - not directly in plan like a wall can, say, but only by editing in profile manager. That is why they made it boss of the profiles.
Dwight Atkinson
and by stretching up the profile e.g: in 3D window
Dwight
True. Stretching constraints CAN be removed, but it seems incautious for the architectural environment - unless you are just playing around.
Dwight Atkinson
