object settings not updating with selected object
I recently ran an update for AC 11, the update no. was 1210 by memory. It has fixed some problems with schedules and worksheets, but now leaves me with a more annoying problem. When I select an object, eg wall, the settings dialog will show the previously selected object eg slab. This makes editing the object impossible.
I then seem to have to alt click the object i want to edit, then select it for the settings dialog to show its settings. Does anyone know of a remedy or explanation for this?
thanks
I find I have this issue if I have trace on, I only turn on trace when I really need it.
