objects help
does anyone know how to get rid of this green fill on the objects?
8 Replies 8
Dwight
Which object is this?
Dwight Atkinson
Rod Jurich
Check to see if you have Minimal Space to show.
You will find it under 2D Representation.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Its a dinning table, on the the furniture layout library.
Rod, it worked for other object that had the same green fill, but it wont work for this object nor the couch object.
Leandro...
(español por si acaso??)
Please give us a Screenshot of the object settings... It will be easier to help you.
Nando
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Si hablo español. Aqui esta. Here it is
This must be the minimal space parameter (considering you are using AC 13). You must turn off its visibility in the model view options window, under "Options for GDL objects" tab.
sorry, im new to this, i can't seem to find exactly where that is at
Nevermind I found it, thank you , gracias
