aryastark
offset edge [but with new nodes]
valar morghulis,
i want to offset edge but without move the nodes from it's parent.
is it exist in archicad?
thanks.
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
1 Solution
No, not by dragging the edge, but there is another way.
If you don't have the extent of where you want to extend to, you will have to draw something (or try using snap guides).
Then use the 'add area' option in the pet palette to add the extra area.
This will leave the original nodes as they are.
Go to post
2 Replies 2
Guru
If you are using the Rotated Rectangle drawing method, there is no need for guides. Just Add Area, click on your two edge nodes then specify offset distance.
Ling.
