Easy-peasy.
Use a Line or a Polyline to offset a spline. Looks identical!
(Procedure is - Select Line or Polyline tool [even the Arc/Circle tool works!], click multiple offset button, hold down spacebar to activate Magic wand, click on to spline, select side to offset by moving mouse, then type distance, hit return!)
Hope that helps!
