2009-02-18
01:39 AM
2023-05-23
03:05 PM
Rubia Torres
2009-02-18 02:12 AM
2009-02-18 04:02 AM
2009-02-18 04:39 AM
2009-02-18 05:18 AM
2009-02-18 02:26 PM
2009-02-18 04:01 PM
laszlonagy wrote:You can also use empty openings at the wall ends to make some logs appear shorter. (This will also show in plan unlike SEOs).
I would use two Walls on top of each other to model the parts of the Wall of different length.
2009-02-27 01:23 PM
Dwight wrote:thanks, that's great.
Investigate the Complex Profile used with the wall tool. It allows you extrude any section into a wall.
http://www.archicadwiki.com/Creative%20Uses%20of%20Complex%20Profiles
All words Greek.
2009-02-27 01:24 PM
s2art wrote:Hi,
(Once will do. You can delete the other identical thread before someone replies to it. And are you in St Helens, UK or somewhere else? Log homes - whatever next?)
