2005-12-20
		09:03 PM
		2023-05-26
		03:10 PM
			Rubia Torres
2006-08-12 03:33 AM
2006-08-12 05:56 AM
2006-08-12 08:56 AM
LiHigh wrote:LiHigh:
David,
As far as INT Library is concerned, I don't think unhiding AC_MarkerFill would works.
Here is part of the 2D script extracted from "Marker Head" (macro) which is used in Standard Detail Maker 10. Clearly, even AC_MarkerFill is set to Solid Fill, we won't be able change Fill Pen color.
if AC_MarkerFill<>0 then fill AC_MarkerFill
fpn=2
bpn=91
poly2_b 2, mask, fpn, bpn,
0,0,901,
AC_MarkerSize/2,360,4001
2006-08-12 09:10 AM
Burginger wrote:Mark:
That is what I am finding too. Screen shot attached. You can toggle on the fill, set it to solid, but then you can't specify a white pen.
2006-08-12 09:18 AM
2006-08-12 03:57 PM
Thanks, that does work once I checked the Model View Options to "by element".
