opening AC7 in AC12
is it doable?? i tried opening an AC7 file in AC12 and it said its incompatable?
6 REPLIES 6
Aaron Bourgoin
you need AC10. install it, patch it, open the files you want and save them as v10. Then open in 12
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / USA AC29.0.1 USA
Rhino 8.24 Mac
MacOS Tahoe 26.0.1
Thats Practical GS
Aaron Bourgoin
That's progress GeNOS
MacBook M4Pro
Rhino 8.24 Mac
MacOS Tahoe 26.0.1
GeNOS
There's a list on the Wiki that tells you what versions can read and write back to each other...
http://www.archicadwiki.com/ArchiCAD%20versions
kinda useless if u only have 11 and 12... every other program on the planet opens anything from its previous version.
Brett Brown
See if this helps http://www.graphisoft.com/support/archicad/downloads/Fileconverter.html
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
