I can not use a keyboard shortcut to Drag a Copy. It works fine from the menu, but not Option, Apple+D. I can change it to Option, Apple,+Q for instance but not the default. Anyone else experiencing this in AC7.0r3.
IIRC you need to disable the system shortcut that conflicts with AC. Go into settings -> keyboards -> shortcuts and look for the one that says "show/hide dock" and unselect it. This will let AC use the shortcut.
