panther problem
I can not use a keyboard shortcut to Drag a Copy. It works fine from the menu, but not Option, Apple+D. I can change it to Option, Apple,+Q for instance but not the default. Anyone else experiencing this in AC7.0r3.
Erwin Edel
That's a version of ArchiCAD from 2001 and OS from 2003, I doubt you'll find anyone still using that.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Eduardo Rolon
IIRC you need to disable the system shortcut that conflicts with AC. Go into settings -> keyboards -> shortcuts and look for the one that says "show/hide dock" and unselect it. This will let AC use the shortcut.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
