perspective view problems
Hello I don't know why but suddenly i cant see anything in 3d perspective view. I'm working on a template for my firm so i drew a wall and opened the 3d perspective view. it didn't show me anything. in the 3d projection setting doesn't show a camera at all. the wall is visible i axonometric view. what is going on?
6 Replies 6
Try the 'Fit in Window' command at the bottom of the 3D window.
Although you may not have a camera set up Archicad may just be looking in the wrong direction.
i tried that. and nothing cam up is i wrote it's like there is no camera. normally when going to the projection settings you can move your current view marked with a camera. there is no camera.
I tried placing one manually but that didn't work either
Erika Epstein
alt/option +click in the preview window or your screen shot where you want the camera to be looking. Notice you can also adjust the camera distance etc. on the right.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
David Maudlin
And Shift-Click to place the Camera position.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Shiftclick worked thanks
THANK YOU! shift-click to place the "eye" in the ctrl shift F3 got me bck on track too.
Funny the things you find out about the gaps in workflow technique..
