placing drawings in elevations
it's just a bit annoying but when i place drawings that have a white background, they show as having a black background in the elevation window but are fine (i.e. transparent background) when i print.
is there a way to turn on transparent background in the elevation window?
15 REPLIES 15
Djordje
Do you have Artlantis?
Check >disk<:\Program Files\Artlantis\Medias\Objects\2D Billboards\Vegetation 2D
You can use any of them, and it will work.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
i don't unfortunately. i only have ac10 and i'm very grateful for it. i use it only for projects that i design and build myself so i can't really justify spending more on other software as i only design 2/3 projects per year. the bitmaps i have come from anywhere on the net where they are free!
i have looked into the alpha channel on corel photopaint and it corresponds exactly to the part of the bitmap i want to hide. i have tried to save in other formats and although another part has become transparent, it's still far from a good result...
Djordje
Then go to archicado.free.fr and download some ...
Djordje
HP Omen
i can't believe it was the image file all along...
tried the website site and the files work a treat - thank you so much Djordje
one last question - is it possible to make these billboards cast shadows or is that asking too much?!
Djordje
If they were proper 3D objects, they would have. See the ArchiFacade hint below. And it would probably slow down the S/E generation significantly.
Djordje
HP Omen
