Really got to love the way GS really do show how they support Mac uses.
Below is the thread of a simple problem with ArchiCAD 15.
What is the likely hood apparently of it being fixed? Well it should be fixed for AC17!!
Thread follows:
Jonny Breen, Nov 22 16:57 (NZDT):
Hi Karl
Tried it on my Win 7 64 bit PC & it worked fine
Since you asked I tried it on my colleagues Mac Lion
The problem happens there
So... I had a look at Graphisoft HQ support cases and found a similar issue
The problem is exclusively with Mac's in the project & view map, saving it as a PDF view or printing from a layout does not have this issue
They are looking into this issue and aim to have it resolved for AC17
Regards
Jonny
Karl Barker, Nov 22 16:26 (NZDT):
Did you try it on a mac running Lion or a PC?
Regards,
Karl Barker
Architect
+64 9 3734900
+64 27 2465452
Construkt’s website has been updated. Click here to view
Attachment(s)
Jonny Breen, Nov 22 15:27 (NZDT):
Hi Karl
I opened your file & placed a marquee (screenshot attached)
Then File>Print Marquee area, to A4 page (fit to page)
Works 100% here (scan of print attached)
Also tried printing to scale (incase Fit to page was fixing an underlying issue) but that has worked also
I would check that everything is up to date & try other printers/workstations to see if the problem is consistent or limited to some machine
Regards
Jonny
Attachment(s)
SKMBT_C45212112214090.pdf
Karl Barker, Nov 22 14:06 (NZDT):
With some files, when a plan view is rotated, we can not print a marque selected area.
The print is offset to the actual marque.
If the rotation of the view is reset back to normal, the printing of a marque area is fine.
Regards,
Karl Barker
Architect
+64 9 3734900
+64 27 2465452
Karl Barker.
27" iMac 3.6 Ghz Intel Core i9
32 Gig Ram
Mac OSX 10.14.6
AC 5.5 - AC22 (NZE)
