2020-11-14 10:24 PM - last edited on 2023-05-09 03:48 PM by Rubia Torres
• If you still want to use a Slab for this then you will need to place this slab in a dedicated layer with a different intersection number, 0 or 500 and then it will not intersect. -ejrolon____________________________________________________________________
valarmorghulis,
i made complex profile.
attached to beam.
used beam magic wand tool to wrap around of basis.
but it didn't work.
when i try to elevate profile to higher than where it should be, it works.
but when i put it to the where should it be in goes almost invisible.
ps->>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
this is basis.
when i change it's reference line to lowest layer & it happens when i try again with beam complex profle.
ps2->>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
ps3->>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
i tried with wall tool by allowing complex profile to use with wall.
but then this dialog box appeared every time.
i tried it with ALL stories. but everytime this dialog box appeared and always complex profile invisible in 3D. (even if continued)
2020-11-15 06:51 AM
2020-11-15 07:28 AM
2020-11-15 06:40 PM
2020-11-15 07:01 PM
Hmooslechner wrote:thank you for your effort to solve. also vimeo is 10X better than lbry.tv (lbry is too slow).
Because this library-link (LBR) is so slow, i switched to Vimeo:
https://vimeo.com/479563572
hope it helps
