aryastark
problem: how can we add a composite to the side faces of the slab?
valar morhgulis,
i want to add composites side face of the slab. how can i?
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
1 Solution
Lingwisyer
Guru
Use a Complex Profile beam?
Go to post
3 Replies 3
Lingwisyer
Guru
Slabs can't have composite end profiles.
Because you want to wrap it underneath slightly, it will be easiest to add a wall or beam composite as suggested by Ling.
Or if it just in a section and doesn't need to be modelled, you can just add some lines (although I don't like adding 2D lines if it can be avoided).
If it was just down the edge of the slab, you could add a modifier to the wall composite to allow you to stretch just the membrane skin down (but not wrap it underneath).
aryastark
thanks.
if there are other people in need of information around can watch this-> https://youtu.be/96p6qKMRucg
I didn't know we could modify the layers one by one.
furher watching for this advice -> https://www.youtube.com/playlist?list=PLnXY6vLUwlWUJmDnD8UGZKPyR9tm4ge8H
Ver: AC23
Memory: 16384MB RAM
