problem printing dots in fills w/smallest pen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2004-11-17 09:23 PM
2004-11-17
09:23 PM
We've always assumed the #1 pens of 0.00 size basically defaults to the smallest printable line. Till this new version there hasn't been any problems.
Anyone having the same problem or other fixes?
Thanks,
Rob
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-11-18 12:16 AM
2004-11-18
12:16 AM
You should not use zero thickness pens. Most printers and plotters are now capable of 600dpi or greater. This results in an almost imperceptible line weight and invisible dots. For extremely fine lines use 0.05 to 0.10mm. Fine lines range from 0.10 to 0.18mm. Dots require heavier pens to be visible than do lines.
