SOLVED!
problem: slab and beams' lines don't intersect
aryastark
valarhi,
i couldn't solve that, used all my weapons still these lines showing, didn't understand. it should be solved.
this line shouldn't show.
checked:
*they are in the same layer both with same number of intersection.
*they are with same material.
*they are not checked with "always show countour line" checkbox.
ps info
______________
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
13 REPLIES 13
Thanks Christophe. Its ok now.
aryastark
Braza wrote:
mnguyen wrote:
LaszloNagy wrote:
thanks to all for advices.
didn't try SEO method.
but converting the closer line to thick white method working just for when it include only lines.
it doesn't work when we fill for the coverings.
well, i can live with that, but may be you find some intelligent better solution to add to the next generations of archicad, to be in your mind.
why it doesn't work with fill?:
the solution might be covering the area with fill tool though... but extra laboring is contrary to the logic of using programs, programs exist to facilitate the implementation.
Ver: AC23
Memory: 16384MB RAM
Ok... here is another one: Model your main slab to the outer limit > Create a Complex Profile with just the angled plaster for the slab edge (no air BM. This way you avoid the 3d edge line.) > Apply the beam on the slab contour > Do a SEO on the slab with a downward extrusion > Put a background fill on your slab and move your beam to the background. Didn't try, but I am pretty sure it will do the trick.
aryastark
now it worked well :]
Ver: AC23
Memory: 16384MB RAM
