problem: slab and beams' lines don't intersect
aryastark
valarhi,
i couldn't solve that, used all my weapons still these lines showing, didn't understand. it should be solved.
this line shouldn't show.
checked:
*they are in the same layer both with same number of intersection.
*they are with same material.
*they are not checked with "always show countour line" checkbox.
ps info
______________
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
Minh Nguyen
Thank you very much for the question! This is an interesting one!
After some brainstorming, with the help of my colleagues, we found a way to eliminate the line in floor plan, without using SEO:
- Set the slab's Outlines to any white pen
- On the floorplan, bring the slab to the front by right-clicking the slab > Display Order > Bring to Front.
I attached a small project file showing what I mean. I hope this is a viable solution if SEO becomes too heavy in your project.
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
13 REPLIES 13
Greetings Arya Stark, your Royal Highness !
Columns and beams have priority over slabs like this :
You are able to do your slab without beam like this :
About slabs only you can check your model view to choose an option to display or hide the dividing line :
[img=https://help.graphisoft.com/AC/24/INT/_AC24_Help/130_UserInterfaceDialogBoxes/EliminateLines.png]
[/img]
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
aryastark
_________________________________________
Thank you my Lord, please stand up.
[img=https://i.ibb.co/HzrxhnJ/Capture-d-cran-2020-04-24-14-23-30.png][/img]
yes i am aware it from here:
https://tinyurl.com/y3hqqqou
[img=https://i.imgur.com/4HM5i53.png][/img]
it actually was again my problem, u can check from here->https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=70624&p=315790#p315790.
and you can see i am using complex beam profile because of slab don't has "relative hinge option" so it doesn't work for negative angle.
though ARCHICAD team told they will add this option https://archicad-talk.graphisoft.com/viewtopic.php?p=315896#p315896 in the future but i am not in the future for now.
did they add this option to VER.24?
and i looked also to these:
About slabs only you can check your model view to choose an option to display or hide the dividing line :[img=https://help.graphisoft.com/AC/24/INT/_AC24_Help/130_UserInterfaceDialogBoxes/ShowLines.png][/img]
[/img]
[img=https://help.graphisoft.com/AC/24/INT/_AC24_Help/130_UserInterfaceDialogBoxes/UseHidden.png][/img]
and still my problem is valid, my lord.
Ver: AC23
Memory: 16384MB RAM
To avoid the inner contour line, you will have to model your main slab to the outer limit and then cut the negative angled base with a morph profile using SEO. (Air space with high priority+plaster). When you get the intended geometry, then you hide the morph edges as wish. Profiled Beams can do this, but you can't hide its edges.
Hope this helps.
I think it's the best solution.
Christophe - FRANCE
Hope this helps.
Or a Wall or Beam using a Complex Profile.
Minh Nguyen
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Thanks for the help Minh (And the "Brainstormers"). (( BTW "Minh and the Brainstormers" sounds like a cool rock band name, isn't it?))
Indeed this is a much more simple and effective solution.
Just a small remark: Don't forget to give a thicker lineweight for the white pen, or you will still see the beam edge with "True Line Weight".
Yes. But the thing is that I can't hide the Profiled Beam because it has the side plaster cover. And the Air BM show the edges on 3d, which is not acceptable for a proper documentation. This is why I also created a wish for Hide Building Material Individual Edges on Complex Profiles.
Your link seems to be broken 😕
Christophe - FRANCE
