‎2020-11-15
08:22 PM
‎2023-05-25
05:32 PM
Rubia Torres
Solved! Go to Solution.
‎2020-11-17 02:57 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2020-11-15 09:45 PM
‎2020-11-15 11:24 PM
Christophe wrote:Thank you my Lord, please stand up.
Greetings Arya Stark, your Royal Highness !
yes i am aware it from here:Columns and beams have priority over slabs like this : [img=https://i.ibb.co/HzrxhnJ/Capture-d-cran-2020-04-24-14-23-30.png][/img]
https://tinyurl.com/y3hqqqou
it actually was again my problem, u can check from here->You are able to do your slab without beam like this : [img=https://i.imgur.com/4HM5i53.png][/img]
and still my problem is valid, my lord.About slabs only you can check your model view to choose an option to display or hide the dividing line :[img=https://help.graphisoft.com/AC/24/INT/_AC24_Help/130_UserInterfaceDialogBoxes/ShowLines.png][/img] [img=https://help.graphisoft.com/AC/24/INT/_AC24_Help/130_UserInterfaceDialogBoxes/EliminateLines.png] [/img] [img=https://help.graphisoft.com/AC/24/INT/_AC24_Help/130_UserInterfaceDialogBoxes/UseHidden.png][/img]
‎2020-11-16 10:45 AM
‎2020-11-16 03:30 PM
Braza wrote:I think it's the best solution.
To avoid the inner contour line, you will have to model your main slab to the outer limit and then cut the negative angled base with a morph profile using SEO.
‎2020-11-17 09:31 AM
Braza wrote:
To avoid the inner contour line, you will have to model your main slab to the outer limit and then cut the negative angled base with a morph profile using SEO. (Air space with high priority+plaster). When you get the intended geometry, then you hide the morph edges as wish. Profiled Beams can do this, but you can't hide its edges.
Hope this helps.
Minh Nguyen
GRAPHISOFT
‎2020-11-19 10:38 AM
‎2020-11-19 10:54 AM
LaszloNagy wrote:Yes. But the thing is that I can't hide the Profiled Beam because it has the side plaster cover. And the Air BM show the edges on 3d, which is not acceptable for a proper documentation. This is why I also created a wish for Hide Building Material Individual Edges on Complex Profiles.
Or a Wall or Beam using a Complex Profile.
‎2020-11-19 12:34 PM
Braza wrote:Your link seems to be broken 😕
