‎2007-01-22 07:07 AM
‎2007-01-22 08:25 AM
‎2007-01-22 09:06 AM
‎2007-01-22 09:16 AM
‎2007-01-22 09:29 AM
‎2007-01-22 06:12 PM
‎2007-01-22 09:51 PM
‎2007-01-23 12:15 AM
Djordje wrote:Yes I agree, expanding memory might help solve the problem if it is indeed 'the' problem. 3djunior....I also suspect it might be a corrupt element in the 3d model. I tell you this because I have experienced the same thing with archicad 9 just about 2 weeks ago on my mac at work. Except that it did not crash and close archicad....instead it 'hanged' and was not responding, after having repeated the same process 3 times, I was convinced that it had to be something in the model because when I rendered in other views with certain layers turned on it would render fine...no problem, but when I tried to render this one particular view with its own different layers turned on (for rendering purposes), it would hang and not respond forever. So, as an experiment, I erased things that were shown in that one particular view....long story short, I discovered that it was a 3d tree that was causing the problem. How to find which is the corrupt element? I'm afraid there are no easy methods unless anybody else could recommend one?
Expanding RAM will help; I don't think that you have a corrupt element, just not enough memory in the computer for what you are using it for.
‎2007-01-23 05:34 AM
‎2007-01-23 05:41 AM
