problem with objects visibility on section
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2016-09-19
03:11 PM
2023-05-23
04:17 PM
Rubia Torres
2016-09-19
03:11 PM
Archicad 19
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-09-24 04:27 PM
2016-09-24
04:27 PM
Make all Layers visible and check to see if there is some other element (most probably a Wall) the geometry of which coincides with the Beam.
Beams are connected to certain other element types when their geometries are colliding in 3D:
http://helpcenter.graphisoft.com/guides/archicad-19/archicad-19-int-reference-guide/elements-of-the-...
Each element has a Building Material and the Building Material has an Intersection Priority Number as can be seen in the Options\Element Attributes\Building Materials Dialog. The element with the Building Material having larger Intersection Priority Number will cut the geometry of the other colliding element. This way your Beam could have become invisible (cut completely by another element).
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-09-25 12:35 AM
2016-09-25
12:35 AM
thanks... intersection priority solved the problem aa you directed.
