problem with vectorial 3d hatching
How to fix this problem with vectorial 3d hatching? Walls are on different storys and fills don´t fit.
David Maudlin
arlis:
It looks like the vectorial 3d hatchings are running in the opposite directions (maybe the walls were drawn left/right and right/left). In the 3D Window, select one of the walls, use the command Align 3D Texture > Set Direction..., click on the wall, the Align 3D Texture dialog box appears, select Define angle numerically, and enter 180Ëš.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Stephen Dolbee
Another option: Select one wall (or the other) then, Edit/Reference line and plane/Invert wall direction.
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
