lmcardoso
project from 24 to 25
Hi everyone,
Usually i keep the rule of keeping the project in the version i started it with but we we have this project at the beginning stages done with 24 but i think it would be good to have it in 25.
We have 2 files in v24 , 1 for modules and a main file where all the modules come together.
What could go wrong if i open de 24 file with version 25 and save it as 25 version ?
Could copy paste from the v24 to a new file v25 be a better solution ?
Also what is your experience so far with 25 ? still a lot of bugs or after 6 months is it already a stable version ?
thanks in advance
ArchiCAD 23/25/27 with Win 10
1 Solution
There is also the whole Archicad 25 Migration Guide which will detail all the things you need to consider when migrating projects to Archicad 25 from earlier versions:
https://help.graphisoft.com/AC/25/INT/#t=_AC25_Help%2F010_MigrationGuide%2F010_MigrationGuide-1.htm
Go to post
2 Replies 2
Gordana Radonic
Community Manager
Community Manager
Hi @lmcardoso
What I can say is that you should always have host and module files in a same version, so if you are updating to 25, make sure everything is updated. Opening 24 file in version 25 is much better option than copy/pasting.
Graphisoft developed a guide for template upgrade from one version to another, there are good advices in what to pay attention when you are shifting to a new version, usually we list all differences and things to consider for features that are changed or upgraded:`
https://learn.graphisoft.com/visitor_catalog_class/show/34404
(If you are on subscription, contact your Graphisoft representative to get access to this document).
Regarding stability, Archicad 25 has update 2 which contains some bug fixes but also couple of new features, but pay attention because update 2 version is also not backward compatible. You can find all details here:
https://community.graphisoft.com/t5/Let-s-get-started/Archicad-Keeps-Getting-Better-Archicad-25-Upda...
https://community.graphisoft.com/t5/What-s-new/Archicad-25-Update-2-is-out/td-p/319431
I am sure other community members will share their experience with upgrading.
Good luck!
Gordana Radonić
Community Manager
