"Elevation dimensions" on plans?
I was trying to make dimensions showing height of certain points on my floor plan. But I didn't manage to get anything reasonable.
Suppose I have a wall of height 4000 and base level of 0. How can I make level dimension of top or bottom of this wall?
Or I have a roof of some not rectangular shape. How can I check what is height of this roof in certain point measuring it (not making additional geometrical construction) in 2D plan window? And how to show this dimension on plan, associated with this roof if possible to be updated automatically when roof angle changes?
Can somebody point mi right way to do this?
Krzysztof Meldner
17 REPLIES 17
Peter wrote:
..... roof label that read the underside
elevation of the roof .....Peter Devlin
Exiting!
Where and what is this roof Label and how?
Thanks,
Joseph
__archiben
Petros wrote:
If you select one level dimension text and press CTR+A all of them will be selected and then you can ask for all of them to change to the reference level.
fantastic! well. almost - having it available just as the other dimension tools would be far better. i had always just assumed that the "autotext" options simply placed text after the measured value.
thanks petros!
~/archiben
b e n f r o s t
Peter wrote:
....... roof label that read the underside
elevation of the roof could be used to display ceiling height.
Peter Devlin
Very exiting, where is this label and how do I go about it?
Thanks.
Joseph
Joseph,
John Hyland suggested this in a thread called "Reflected Ceiling Plans".
I don't know which label he was using.
Perhaps John could tell you.
Peter Devlin
Petros Ioannou
that is because there is one right below . Sometimes i think my eyes play games and i see things double in that dialogue.
Anyway I am glad I helped.
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Peter wrote:
Joseph,
Peter Devlin
Did not have luck finding the post or John Hyland to PM him, so I guess we wait to hear from him.
Thanks,
joseph
Joseph,
John Hyland is" Aussie John".
He has contact information in his signature.
Do a search by author or a member search.
Peter Devlin
Aussie John
Peter wrote:
Joseph,
Also, someone a while back suggested using roofs as floors
so that a roof label that read the underside
Peter Devlin
For info, the level displayed is only the height of the pivot reference of the roof.
The global variable "glob_elevation" would work for slabs too, just need to take off the thickness of the slab if you need the underside. (result height above storey)
Edit: if you include Glob_ID in the script you can easily control the description of the level from the info box
or add a parameter to make a level relative to the origin rather than a height above the storey using "GLOB_CSTORY_ELEV"
Cheers John
[/size]
