"Magic wand" in Archicad 17
Could someone please tell possible reasons why I cant select curved lines with "magic wand" (using space+click) in xref dwg file which is set as"Show as trace and Reference" while i am working on Ground floor in Project map?
The purpose is to add those curved lines to mesh.
3 Replies 3
Hi, Everita. Try exploding the xref files that you had imported and then use them as a reference file. Depending on the settings of the dwg/dxf translator you get different outputs when importing so this might be imported as "Drawing" and this usually has the boundaries set to the outer most of the drawing itself. So every time you try to use the magic wand on the lines in that drawing it creates a rectangular shape from the drawing. Try exploding and chose the "keep drawing primitives only" radio button.
Link
As nestorovski points out, your DWG has probably come in as a single entity. If you drag and drop a DWG into your project for instance, it will come in as a 'Drawing', using the Drawing tool. The beauty of this is that it is just one element, and it contains the full original layer set embedded within it (accessed via the Drawing's Settings, under the Properties tab).
The downfall with this is that whilst you can snap to nodes within the Drawing, you can't magic wand them. Instead ArchiCAD will magic wand to the extents of the drawing.
If you do explode your drawing, just be aware that all of its embedded layers will become part of the project by default. Attribute pollution!
So you can either hide the unwanted layers prior to exploding to reduce the amount of layers that are consequently created in your file. Or if layer visibility within the DWG is not a big concern you could uncheck the 'Keep Drawings primitives on elements' original layers'. This would put them all on the same layer as the Drawing itself is on.
Link.
Link
And the Explode options. I would tend to keep the original elements too.
Link.
