2012-01-18
12:57 AM
2023-05-23
04:38 PM
Rubia Torres
2012-01-18 02:21 PM
2012-01-18 10:18 PM
2012-01-18 11:34 PM
2012-01-19 12:49 AM
Karl wrote:
The behavior of the "Elevate..." command - and thus the ctrl-9 or cmd-9 default shortcut - changed in AC 13 to display the numeric adjustment dialog.
The Pet Palette mentioned by David is the way that visual / drag and snap elevation changes are done now. Once you've clicked on the elevate button (up/down arrow as shown in attached screenshot), everything is as it used to be for you with ctrl-9.
It takes only a second extra, and given that you can elevate any number of things in one step, I'm not sure how this is a deal-breaker for your workflow. Seems to me that if you have to change the base height of things as often as you suggest (such that you would not leave AC 12 because these 'seconds' would add up to 'hours'?) that there is a bigger problem in your modeling technique.
2012-01-19 06:35 PM
2012-01-20 02:39 PM
2012-01-21 08:49 PM
2013-04-09 06:27 AM
