I stand corrected.
'Create opening from selection' will create an opening from a selected window.
I don't have the same USA library objects that Jared would have used.
When I try with the AUS library windows, I find that the reveal has to be set negative to the wall so that the window opening (Wallhole) extends into the extra wall skin.
Maybe it has something to do with the extra external trim that Jarred has on his windows (I see his reveal is set to 0 (zero)).
I tried adding an external casing but that did nothing for me.
I will have to try some further experiments.
There can be a gap between the walls, but I am finding that the window reveal depth has to be a negative value slightly larger than the gap (it can be set back after the opening is created).
I am not sure how Jared is doing it with a zero reveal depth - I am guessing it is something different in the USA library as I know the windows are scripted differently to INT/AUS windows.
