"offset“ not applicable to circle....
Hello, I want to offset a circle (ora curve), but the reshape-offset or control-offset not affect it, very weird I cannot apply this basic function any shape....
Please advice, thanks
1 Solution
I assume that because it is a single arc, it is treated as an actual arc.
Arcs and circles do not have this offset edge option in the pet palette.
You can however use the offset tool.
See this post from just a little while ago.
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=72001&p=322323#p322267
Go to post
4 Replies 4
Lingwisyer
Guru
Select the edge of the arc, not the node?
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
Hello Lingwisyer,
I tried but can not.
when pline two curve it works, but just a single curve cannot....
Thanks
OK Thanks Lingwisyer,
