"walhole" v.12
can some one check out if labeling a slab wallhole does what it is supposed to in v.12- it does not for me
6 Replies 6
Allright Allright, I lied I guess.
How ever- did you guys know that the wallhole ID only works if you have selected that you want the part you are saving to be an editable binary 3D part.
I didn't know. & I was saving it as non editable.
Dwight
Your choices are editable GDL or binary, and yes, saving binary means a wallhole AND a slab at the same time.
Okay, now?
But for my first time through that with a full - not beta - Archicad 12, the preference WAS set to binary... Duh.
Dwight Atkinson
Oh, I guess you're right- So I guess I meant it needs to be Editable GDL.
archigreen
Where can one chose to be editable or not?
ArchiCAD 26
MacOS Monterey
MacBook Pro Apple M1 Max
64 GB
archigreen
Where can one chose it to be editable or not?
ArchiCAD 26
MacOS Monterey
64 GB
David Maudlin
archigreen:
In the Save As dialog box for library parts, at the bottom left corner there should be two tick box options: Save in Binary Format, and Create New Library Part. Do not check the first, do check the second. (This is looking at AC21, assuming AC20 is the same.)
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
