radius of arch?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2014-01-21 11:29 AM
‎2014-01-21
11:29 AM
How can I please measure the radius of an arch in Archicad?
Thank you.
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-01-21 11:38 AM
‎2014-01-21
11:38 AM
Sure just use the radial dimension tool.
Or the Measure command. If you hover over the arc, it's centre point should show as a cross. Measure from that to the edge of the arc.
Link.
Link.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-01-21 12:49 PM
‎2014-01-21
12:49 PM
Thank you. I managed to do it.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-01-21 08:41 PM
‎2014-01-21
08:41 PM
Another way is to select your arc and stretch with the Radial Stretch button on the pet palette, hover over the arc and the radius will display in the tracker. (Screen capture a bit crazy because the figures change while I'm trying to snap the image, but you get the idea).
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-01-22 07:29 AM
‎2014-01-22
07:29 AM
Thank you for the answer. I tried this, but it only displays the angle, cord and arc length.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-01-22 07:34 AM
‎2014-01-22
07:34 AM
Clicking on a node, gives you a slightly different pet palette.
You should try clicking off a node, or hit tab and tab through the tracker until the Distance appears.
Link.
Link.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-01-22 10:55 AM
‎2014-01-22
10:55 AM
Now I got it. Thank you.
